You must enable Flex UNI to create a Switched UNI service.
Use the following procedure to configure a Transparent Port UNI or Switched UNI by mapping an I-SID to a port or MLT and VLAN together.
If you configure a T-UNI to terminate on a port or MLT on a switch in a vIST switch cluster, you must also configure the T-UNI I-SID on the other switch of the vIST switch cluster. You must configure the T-UNI I-SID on both switches of a vIST pair. You do not need to assign an actual port or MLT to the T-UNI on the second switch.
You must first create a type of service instance identifier (I-SID) to create the different types of services available. After you create an I-SID you can add members (ports or MLTs) to the I-SID to create end-points for the service.
- Select ISID.
- Select the Service tab.
To create a Transparent Port UNI service:
- Select Insert.
- Select elan Transparent in the Type field.
- Enter the I-SID in the Id field.
- To create a Switched UNI service:
- Select Insert.
- Select elan in the Type field.
- Select Insert.
Service Field Descriptions
Use the data in the following table to use the Service tab.
Name |
Description |
ID |
Specifies a unique value to identify the service associated with this entry. |
Type |
Specifies the type of service associated with this entry. |
MacLimitEnable |
Indicates whether the MAC limit is enabled (true) or disabled (false). |
MaxMacLimit |
Indicates the maximum learned value of the MAC address for each service I-SID. |
Action |
Specifies I-SID related actions. |
OriginBitMap |
Specifies the origin of the I-SID. |
VnId |
Identifies the VXLAN service associated with this I-SID. |
Name |
Specifies the name of the I-SID. |
